Auris HSD flasher relay
pube
Someone knows where can i find the turn signal flasher relay in auris hybrid 2014?
Maybe can you show an picture of location?
Edit, it's controlled by the instrument cluster
iirc there isn't its done by the bcm (ecub), have you checked the 10A fuse ? (24, under the bonnet ?)
Click to enlarge
https://knigaproavto.ru/shemy/en/toyota/corolla/527-2013-2018-toyota-corolla-and-auris-fuse-box-diagram.html
No error by the flasher. Just too low the control volume. I think, i put an extra speaker to anywhere for flasher control. Maybe like this or other.
i am sure on carista i have seen a volume setting for the flashers
Think you maybe right, Mark. I increased volume on my Prius, and also the number of flashes it did from 3 up to the max 7.
Thank you the idea, but in my country, if i change something through obd, then i lose the hybrid guarantee.
what country are you living in ???
i cant understand why you could possibly lose any part of your hybrid warranty ,
you could be resetting the service light or a feature
that is present in the system through the obd port
maybe ask your dealership to make the change for you.
I would love to be able to see where these Other/NonUK members actually live, what country.
Hungary. The official dealer said.
i feel the dealership doesnt know what they are talking about
in the uk there are dealer customisations that can be changed
via the obd port and these can also be change on a handheld
device i.e. phone / tablet
if you lowered the threshold regarding how much charge you
could use i.e. lowered it to 10% and increased the charge limit to 90%
to enable you to get more miles in ev then yes i can understand
their argument.
  • 3 years later...
Do you know of an app with which I can adjust the threshold of bulbs' resistance / current draw which kicks in an error message? I would like to avoid hyper flashing. From what I've read, carista is not capable of doing so.
