Stock 2ZZ maximum power........
Dread2zz
So, I've been wondering what the stock 2ZZ internals can take, and does anyone know of someone that's pushed one to braking point?
Let me know
It depends on how worn the block/internals are but with fuel and map 200-280 making sure it has the lift bolts and uprated head bolts, build the block, Turbo or SC with a flowed head 380-500
a full uprated gasket set is £190 https://shopbhp.com/collections/2zz-ge?sort_by=
just have a look on the lotus forums, by no means am i knowledgable with the 2zz but have a feel for what things can take
At the end of the day it's what sort of money you want to throw at it £3-4k with get you a built engine with Cosworth pistons and rods
A Cosworth short block will run you £8K with a full engine in the £11-14K http://www.ttlas.com/Cosworth_Toyota2ZZ_0612_5.pdf
Not bad at all, i'll have a look at those links, as always thanks 😁
Oh, i bought a gasket kit off eBay for 27 quid. bargin
