Toyota Extended Warranty Renewed
ihpj
The second year of the warranty always seems to go faster than the first, but you just got to bite the bullet and renew when the time comes. Sadly, given the 12 year rule, this will be the last time we will be able to renew on our Aygo (2009/09 facelift).  At least the price (£345) seems to be constant over the years so with inflation, seems quite reasonable and thats when you factor in ZERO excess at claim and two year coverage with full AA recovery support.
And if history is anything to go by, we will be needing a clutch/actuator assembly/unit late 2021/early 2022 🤣
Safe travels y'all 🤘
Should be possible to extend beyond the 12 years - extract from the terms of the warranty:
"The Toyota Extended Warranty can be renewed until the vehicle is 12 years old or 100,000 miles (at the point of sale of the extended warranty) ..."
If the extension is purchased before the car is 12 years old, then the purchase would meet the above criteria.
https://www.toyota.co.uk/owners/warranty/extended-warranty
Well you did point this out last time and I was able to follow this up with Toyota - I am grateful that you did!
As for the 12 year rule, 2009 + 12 =  2021.  Current Warranty runs from 07/2020 - 07/2022.  Sadly, when the Warranty expires in 2022, we will be outside of the 12 year rule 😫
