Rear Spring
On my Toyota Granvia 2700 camper van the rear springs are to soft i need to put stiffer springs on Toyota dealers would not help can you
Welcome to Toyota Owners Club.
Moved to the Toyota MPV forum.
Can't really understand why.?...it's basically a Toyota Hiace..common enough in the UK.
There are loads of rear springs for the Hiace on eBay.
I am looking to upgrade to a stiffer suspension yes i can get the standard spring but they are too soft
try speaking to a conversion specialist or a company like avo, spax and the like and have the spring made to order
I will have a look tomorrow
what is the rear curb weight (should be on a sticker on one of the door pillars)
The Curd mass (kg) 1820 Model E-RCH11W-GRSGK- its a import flash22 much appreciated
You could have a word with these guys...they buy/import and convert Granvias and the like...if they uprate the springs then they might be able to point you in the right direction.
https://poplarmotors.co.uk/index.php
