Verso 2007 dvd and screen troubles
Chrisbladen
Hi guys just after a bit of advice, just brought a 2007 verso, 1 screen is very dark, i have swapped it to the other headrest and plugged it in and its still the same which leads me to think its a fault with the monitor rather than the wiring. The other issue is that the screen is rolling when the dvd player is selected on the monitor that works.
Firstly do you know if you can get aftermarket monitors that will plug in or does it have to be an original toyota 1.
Secondly any ideas why the screen is rolling? I have checked all the connections i can see under the seat and they all seem to be ok.
Thanks in advance
Can you post a picture of what screen you have as there are a few types, if its dark the backlight has failed
Is the DVD built into the monitor ?
