toyota avensis d4d blue smoke is it the 5th injekter???
ToyotaGang
HI
My 2009 2.0 diesel avensis is smoking i press the accelerator and blue smoke comes out. It is not burning oil or coolent. I guess it is the 5th injekter or egr valve.
Pls help. I dont want to put money on the wrong stuff. If anyone now the problem please answar me.
When the 5th injector went on my RAV4 DCAT, it was more white smoke than blue.
I have cleaned the Egr valve lot of times. It stopped for 3 days. But then it started again....
How can i replace the 5th injekter. I did reseach but no one showed how to do it.
Does your car have a DPF? If not then it won't have a 5th injector.
It does have a Dpf and its a diesel.
My car is a diesel. You mean i shuold let the car run and burn 10 pounds diesel Or cemical cleaner??
22 hours ago, Ikram Shahar said:
HI
My 2009 2.0 diesel avensis is smoking i press the accelerator and blue smoke comes out. It is not burning Oil or coolent. I guess it is the 5th injekter or egr valve.
I have the same problem. My 2011 Avensis t27 2.0 diesel is more like a white/blue smoke (more white than blue) and it only smokes when i accelerate hard at around 1.5-2.0 RPM. Sometimes it doesn't come smoke at all, but most of the times it does when the engine have to work hard.
I recieved this issue 4 days ago. Went to Toyota dealership and they told me that it's the 5 injector. They are going to replace it for free since i bought it used 1.5 weeks ago. I don't know how much this costs to fix, since Toyota is going to fix this for me and the bill as well. Ure safe to drive the car if this popped up recently, but in the long run it will clog up. So, have it checked out at a Toyota dealership if you don't know what casues the problem. This will save you time and money in the long run instead of ignoring the issue, and the diagnostics takes like 20 minutes and you got your answer.
Thanks for the help
Did you get a receipt? If you did cuold you send a foto becuose i wanna see what they fix and replaced.
And you know where the 5th injektor is located?
On 8/27/2020 at 10:16 PM, Ikram Shahar said:
Thanks for the help
Pricetag at Toyota is about 5-600+ dollars for the part alone converted from my currency. Injectors are located under the head gasket and is a "complex" work if you never done it before. I've heard that there are ways to clean them, but don't trust my words on this since i have never tried this before myselfe.
Looks something like this
I hope this gives you a guideline atleast. Happy hunting
EDIT: These aren't pictures from my car. Just to give you an idea what they look like.
Cheap way is 2 stroke oil yes 2 stroke oil 200mil shot straight into tank it will work with diesel to clean all move in parts such as injectors fuel filter system including fuel pump oil pump land rover team have being used it for years increasing loss power bk into engine
Utter tosh!
If you think it isn't tosh, provide proof.
12 minutes ago, Tomm5 said:
Goggle it that's enough proof plus I'm using it
Are you some form of expert on fuels and additives?  No, I thought not.
What you say goes for nothing unless you have evidence to back it up.
Have you got evidence?  No, I thought not.
21 minutes ago, Tomm5 said:
My car runs perfectly after use that my proof
Sorry to wade into the argument, but I take it from Stivino's point of view, that even though Tomm5 has used his method to cure the car cheaply, some components may be affected long term. The modern high pressure fuel and the DPF are what I am talking about. But on the other hand, Tomm5 took the chance and so far the car 'works'! Also there are other components like the EGR and inlet manifold that need cleaning. Hopefully the car has passed the NCT emissions test! Terraclean is doing a similar thing. One thing that can't stop smoke is if the seals/gaskets are failing, especially the turbo seals.
I think Stivino would like to see a video of the exhaust, with the engine revved.
My model car is newer model 12 plate which doesn't have this 5th injector problem because Toyota solved this on my model this injectors fault is 09 to early 12 older model by way I also use kerosene oil too that seems to do trick too and diptane good motor factors told me that's what taxi man uses
I have known some diesel injection specialists swear by using a little 2 stroke oil added to diesel fuel, but never seen an actual scientific study on its effects. I tried it on a Peugeot HDi engine years ago that was suffering (I think) from a sticking injector, and it made absolutely no difference whatsoever, but who knows it may work for some. I would be reluctant to use it on anything with a DPF however.
I have alleredy added the cemical and drove 200 km, after it had the same problem. Mabye shuold i try the 2 stroke oil.
I shuold try the 2 stroke oil, if it did not help i guess the injektor has gone bad.
I really think that is the 5th injketor that is blocked, becuose it dosent smoke somtimes.
And yes i did google it, a lot. The only place i fuond, was here.
It's most likley the fifth injector mate, but please make 100% sure on a dealership. Or if you know someone that can read error codes on your car, or even better, buy your own error code reader perhaps. I don't know much about Toyotas, but people say it's easy to figure out if it's the injector if you have error code reader. My dealership, when i first got there told me that this kind of smoking can be caused by the turbo as well when it kicks in. In my case it was the injector, and this is an known sickness for 2011 (ish) Toyotas diesel. There are also ways to overhaul or to puchase overhauled injectors at a cheaper price as well. So there are many options that doesn't cost to much money as well. Good luck with the problem you have mate.
New ford transit same ford got engine passed euro 5 emissions test never bothered to test engine after that so injectors go unfortunately not good
Mate had 11 d4d same problem good news was he found out problem bad news was car needed all injectors done at cost 1500quid morel story is dont buy 09 to 11 get 12 to 15 plate toyota sorted these expensive faults thanks be to god iron them out
I took it to a mechanic I'm friends with. We found 4 codes but they had nothing to do with the 5th injector and no codes about engine.
It's just that it has not smoked for about 4 weeks.
