More Problems
Darrebe11
Driving IQ 2010 in gear then all of a sudden it was like corks just turning in gearbox making noice but car wasn’t engaging or driving through drive shafts it was like some gear linkage or bracket on gearbox snapped. It goes into gears but when you let clutch out just makes noice like crunching any ideas
Check the drive shafts, it could be a failed CV, worst ways it's a dead gearbox
jack the car up and spin the wheels by hand
I will try that...failed cv normally clickzing noice don’t they? This is more the corgs in gearbox are like making a noice but not engaging the drive shafts....so if the wheels spin in gear it could be CV
If one drive shaft lets go you will lose all drive, the shaft can shear the splines either on the shaft or in the joint if it has they tend to rip the CV boot up
But your right it could be the drive shaft as no other signs gearbox problems....no notices etc...no clutch problems smells or slipping so I think your 100 percent right drive shaft...see these forums are excellent as they get you thinking outside the box
I have jacked up car and put in first the wheels will not spin anti clockwise so any other thoughts
The gear shift is normal goes in all gears but when you let clutch out just noice and no drive....I haven’t tried it in neutral please advise the best way to check thanks
Every gear 1st to 5th and reverse but soon as you let clutch out it makes a noice and doesn’t move
15 minutes ago, flash22 said:
Same as before up in the air, turn the wheel
Be more specific
jack the car up and rotate the wheels they should turn freely have a look at the inner and out cv joints
