Sensitive TPMS?
Rambler56
Anyone finding their TPMS a bit on the sensitive side or giving false alarms?  Mine lit up this morning, checked pressures with an accurate hand gauge and no drops shown on any tyres.  My previous car needed a drop of over 10% before alerting something was amiss.
You normally find as the cold mornings start tpms light issues reoccur they are very sensitive sensors
If set pressure is very close to actual pressure this can be an issue especially as ambient temperatures drop, to overcome this lower your tyre pressures 2-3 psi below normal, reset the TPMS and then raise the tyre pressures back to the correct pressures.
I'll give that a try and keep an eye on it.
