Creaky noise from clutch pedal
roks
Hi All,
So the clutch pedal is making this creaky noise on pressing  and releasing.
On the Auris, I don't see a fork and not sure what to grease.
I've recorded the noise from master cylinder and on top of Bell House, same noise picked up in the engine bay.
Some post talk about replacement of the master cylinder, how can confirm?
On my corolla,  it was the pivot point on the fork, and I  cured it by greasing it by removing rubber  gromet.
Thanks.
Clutch-gearbox.m4a Clutch-master.m4a
Your clutch slave should be inside the bell housing, mounted on the clutch itself, something like this.
I also had cars make the creaking noises, and my Auris now does make some noise, not like creaking, but i dont know how i would describe it, not so loud, for years, still works fine.
If it's not broken, don't fix it.
Well its not broken but !Removed! annoying noise constantly on start stop traffic. Seems to worse during warm weather, early this morning its was barely noticeable.
I know on my Toyota if you spray some grease under the rubber cover on the slave cylinder it cures the creaking.
So, during warm, dry weather its more anoying, but during mornings it's not. Sound like the dew lubricates it a bit :).
Considering the slave is inside the housing, on the clutch, i would not spray anything there.
Pretty stupi design imo, i still prefer the slave being on the outside.
|Gez, yes, I too did fix my 04 corolla that way but these Auris dont have a fork, and I dont know if something can be greased on these.
I used to use a long handle small brush to grease the pivot on the fork.
I can see the slave in the bell housing with my endoscope camera, just need know what is safe to smear the grease.
The piston operates the clutch spring directly.
I would guess the spring inside the slave cylinder (like the one in the picture) might be what's creaking.
You can try to apply a bit of grease on it, but i doubt you can cover the whole spring.
You also need to keep in mind that due to centrifugal force applied to it , it might throw the grease all over the bell housing.
Your grease might be thick, but take in account also the heat from the engine.
I'd still wont touch it, as it works fine.
Thanks furtula, will see how I feel about doing it, if in doubt I'll back out.
Its strange how the sound is coming from inside the bell housing, at first sounds like the pedal, then you look under there, and think the sound is from the pinston on the master cylinder.
  • 7 months later...
Hello, I have the same problem.   Did you manage to fix yours?
Unfortunately I have not been able to progress anything further, the noise is there, dry weather makes it louder.
Also not sure exactly where to spray apply the grease, old corolla had a pivot point and thats where i applied but with Auris its different.
I had this noise on my avensis.it was down by the clutch pedal..wd40 on the cable !
Had it for years on Mazda 3. It was where the slave was pushing on the fork, on the outside of the car. Silent during rain and humid mornings, noticeable during drier days. Did not influence the function of the clutch though.
Some grease would fix it for a few months, until the water would eventually wash it out, as i did not have the underside tray.
Not sure if your Auris has slave cylinder inside the clutch, or outside, but it's quite easy to identify.
Just follow the clutch line down to the gearbox, and see if it's connected to slave on the outside, should look like the picture below, or similar.
If yes, the marked tiny piston is what operates the clutch fork from the outside. You need to apply some grease between it and the clutch fork.
I would usually push the clutch fork by hand, or some lever, a bit, so i can get the grease to coat the whole thing.
  • 2 years later...
Just had the 2013 touring. Only when it gets really hot in the car e.g. left in car park all day in blazing sun.
I have removed the bottom cowling below knee airbag.  Removed and can see the mechanism. A quick squirts of white lube, did solve the problem for a few days.  Now back but not as loud.
First I apply oil then grease to all pivot pins first if that fails try a drop of oil on piston shaft itself after easing off rubber from piston you can test it with rubber off this end and replace it afterwards.
Dont over oil it  as you dont want oil droping down onto the foot pads.
