Battery bracket on Auris 66 plate
Brian Hoey
I took my Battery out of my diesel Auris to charge it up.  When replacing it I had the devil's own job getting the hook on the long bolt at the back of the bracket holding the Battery to locate in the proper hole. If I put it in before the Battery it detached itself. If I tried after putting the battery back it was impossible to see the hole.  Is there a nifty trick that Toyota mechanics use?
