Suspected blown head gasket
Stonecutter
Hi guy, I've been losing coolant from my 2004 LC5 4ltr petrol without seeing any obvious place that it's leaking from plus it's running a bit lumpy on start up and on idle!
What say you? does that sound like head gasket trouble or worse? Cheers
On 9/29/2020 at 12:59 PM, flash22 said:
First step would be a hydrocarbon test to see if there are gases in the coolant
Yes, ta I have that booked in for next Monday, so just got to wait and keep my fingers crossed. Thanks
If after testing it proves positive that's it's blown, and tbh it looks very much like it! Can anyone recommend a good garage that knows there way around a Landcruiser ??? Cheers
Where bout you located mate, the mechanic I use is really good and honest
Sent from my Pixel 2 XL using Tapatalk
Thanks for the reply, Either North London or Hampshire . cheers
My mechanic is in Oxfordshire, Bicester, he does collect on a trailer for a small charge, I can give you his number if you like, he has my 120 Prado at moment
Either Nth London or Hampshire, I may have found a garage near me in Hampshire Red Post services
