W53828/ERROR 1: change CD player only?
socratez
Hi everyone,
I get ERROR 1 on the stock radio/CD unit of my Avensis 2010. I tried with a cleaning disc with no luck. Before I get my hands dirty and remove the whole headunit, I wanted to pick your brains:
- Once out, can I disassemble the W53828 and replace the CD player only? That would be cheaper, presumably, than buying a whole new W53828 for an old car.
Thanks for any other ideas you may have.
I'm with Bob. At just under £36, you might as well go that route. I have the same stereo, but hardly use the CD. I have a Bluetooth/USB adapter plugged into the CD changer socket at the rear. I mainly play music from a USB memory stick, but can play from the phone via bluetooth. This is something the W53828 is missing. I have used voice commands to get directions!
Anyway you have options - simple cheap replacement or add update?
