Rev Counter Retrofit ------
- A - Go -
Hi all, new here !!!  I would like to ask a genral question ... can i fit a Rev Counter from another Aygo on to mine as i currently dont have one! If so how easy is it?
Cheers!!!
J
2010 Aygo
yes, plenty of info on here and videos on youtube Aygo, C1 and 107 it plug and play, someone even fit an Agila B one
5 min job , you can check youtube theres several how to videos
makes it easier if you get the shround with it although you can cut the original one as its marked where to cut , make sure you dnt get a diesel one by mistake
Hi, thanks for all your input guys, s its mentioned not to get the diesel version of the Rev Counter, hi would i know the difference? Would they look the same?
Cheers
J
Never seen one for a diesel tbh, iirc the rpm pulse is generated from the ECU anyway
  • 3 months later...
Hi there, I was planning on installing a Rev counter to my 2012 Aygo, however could not seem to find the connector that it plugs into. Any help would be appreciated
The plug should be taped to the loom as per the vid above, you may need to remove a few plugs to find it
Thanks al give it a try
