Android Headunit plug and play
Biomecanoid
Hello,
Can you please recommend some 2din Android headunits that you have tried?.
The prerequisite here is for it to come with adapters that would fit the plugs inside the dash so i don't have to cut cables/solder, so that i can put back the original radio if i have too, for example if i want to sell the car.
My car is a 2006 Daihatsu Sirion and i have find a proper Fascia The plugs inside the dash for the Radio are the standard TOYOTA ones. My issue with replacing the radio is just the adapters because i don't want to cut off the original plugs. I would like something plug and play.
Thank you
