Toyota avensis t25 rough idle
Toyotaavensis6624
Hi i have a problem with my avensis t25 2.0 d4d 2007
The idle is very rough once the car is warmed up
Cleaned out egr
Cleaned Maf and Map
Checked all vacuum pipes all clear
No error codes scanned with techstream
Attached is a techstream log at idle and up to temp. Would be great if someone could upload a log of a avensis running great so i could compare with my file to see if there is anything abnormal.
Any help would be great
2 hours ago, Tomm5 said:
Best solution here is change car over to vvti that what I did never looked bk
That's not what was asked! help to resolve his/her problem is required! if anyone can help this new member?   tbc/qas/rehj/lmfc!
Saxo265 give over mate u and while avensis club know that these d4d engine  are not very good they give lots trouble any mechanic taxi driver will tell u stay well clear just trying give this chap bit of good advice because these diesel heaps are costly to fix when they start to give trouble!!by way I'm speaking from experience!!!
Causes of a rough idle. Many different problems could result in a rough idle for your car, including: dirty fuel injectors, clogged air filters, bad spark plugs, and a variety of exhaust system issues.
But Tomm5: In my opinion the diesel cars are better and stronger than the petrols ones
Cleaned out egr
Cleaned Maf and Map
Ok thanks car drives great and great mpg 50+ only problem is the tick over is really rough every second or two revs drop then back up settles then drops again over and over again.
Injectors are all in tolerance and have tried redex injector cleaner
Recently had a service new air, fuel and oil filters
Its a diesel so no spark plugs
Also gave it a good rev past 4k to clear out any soot from cat slight puff then nice and clean
I have ordered a new maf sensor to rule that out
And yesterday cleaned out throttle houseing with carb cleaner was very oily but didt make any difference.
Anyone else got any help or has experienced this with there avensis.
Have you tried to clean the egr valve?
I think it cuold be the egr valve.
As In my first post cleaned out egr made no difference i also blocked it off all together with a plate that made no difference either so took plate back out.
Check this topic out. Hope it help.
  • 5 months later...
This is in fact due to bad injektors
Cleaned out egr
Cleaned Maf and Map
