Toyora Auris 2014 - Cruise Control
Kobi
I installed CC to my Auris using this guide and got P0571 error, and CC isn't working.
I saw the solution here but couldn't understand where the exact location of A130 and A124 and what I need to do in order to get in touch with those connectors.
Please guide me how to do it, I hope this will be the last solution that will solve my issue..
Thanks guys.
Kobi,
The solution tells you the location of those connectors, you need to check to see if there is cable missing on the pins for each connector.
Quote
ECU plug is A130, the pin 7 that connects to the A124(switch pedal) plug, pin 5
I am guessing these connectors will have these labels on them, from diagram A124 is near the brake pedal and A130 is on the passenger side.
You going to have start removing some panels and locate the ECU.
Hope that helps
Hi Roks,
Thanks for your help, I appreciate it a lot.
I still cannot understand exactly the location of the two connectors, can you add pictures and eloborate what panales I need to remove please?
I have a Toyota Auris 2014 Left Side Wheel.
