2017 Aygo x-touch upgrade to apple car play
cornishmatt
Hi, my girlfriend has a 2017 Aygo x-press with the x-touch stereo that has the DAB option fitted.  Am I correct in thinking that if I fit 86140-YV020 it will be a plug & play upgrade to the unit that has Apple car play?
Someone on a non-Toyota forum swapped the stereo for one with that same part number but found that the firmware was too old to have CarPlay enabled, and they haven't been able to find the newer firmware to be able to update it - so AFAIK you need to check the firmware levels and/or ask the seller to confirm that CarPlay is enabled.
