2020 Aygo coolant loss since Feb - pics in post
wadi16
Hi everyone,
New Aygo owner so I'm not sure if this is normal
But on the left in the photo is my coolant level when my car was 1 week old vs just now (conditions same). Is this decline normal?
Not sure if a car is New if sometimes the coolant declines to a certain level? Someone mentioned expansion of hose pipes? I never noticed this in my Corsa
That looks fine to me.  The container is called an expansion bottle so expect to level to rise and fall a little.
As long as it stays between the marks on the bottle, everything it ok.
Just keep an eye on it, if you can't see the fluid in the bottle, then you can start to worry.
Thanks for your response.
Is it normal for the coolant to never return  to the levels seen when it was brand new though? I've only ever noticed a very very slow decline (I check every 3-4 weeks) and the coolant has never returned to the levels photographed in Feb. All of the photos I've taken since Feb show a regular slow decline.
Was going to bring this up with Toyota but currently avoiding leaving home too much.
