Speech commands
mrmick53
Hi all.
Is it possible to use speech commands for sat nav please? Every time I try it, all I get is PARDON?  Corolla 2020 1.8 Hybrid.
TIA.
38 minutes ago, mrmick53 said:
Hi all.
TIA.
Have you checked in your Handbook Mick ?
Hi yes I have. I seem to be able to give a command but it is not understood?
Mick, if you are giving the Command exactly as the procedure and the Handbook requires, then try giving it in a regional dialect eg Souse, Cockney, tyneside etc.
Have you checked that the Command is listed ?
Hi again.
Yes It just doesn't seem to recognise my speech, I would not say I have any accent. Thanks for your help though,
When you short press the "Talk" button you get Toyota and on screen there are options displayed if you press more commands you can see the entire list, you have to match these exactly any deviation and you will get "Pardon"
A long Press will get you either Google or Siri which voice function are you talking to?
Hi all.
I have cracked it at last thanks to everyone that offered advice.
1 hour ago, mrmick53 said:
Hi all.
OH,come on Mick-spill the beans !!
