Rev Counter. Aygo 2005
douglasblack5
Hi, I have aquired a Rev counter, from a 2012 on I think ?
Rev counter wires, which have been cut and plug removed are ; Red, White, Yellow, Brown, Blue.
Wiring from loom is ;        Red, Black, Green, Brown, Blue
Can anyone advise which connects to which please.
Thank you
Did you give up on the Agila one then, do you have a part number of the rev counter
What car did it come from ?
Aygo tacho.pdf
Red - IG 12V
Black - RPM signal
Green - Illumination
Brown - Ground
Blue - Perm live
So working this out from pictures, pinouts and C2 housing diagram
Looking at this and other pic's we can see yellow and white are next to each other and a blue
Looking at this one we can see that the brown is on the top row
Looking at another pic we can see 3 wires on the top row in positions 1, 2 and 4 the connector uses 5 pins of the 8, 3 on the top row ergo. 2 on the bottom row
Car Side
Red - IG 12V - Pin 1
Black - RPM signal - Pin 2
Green - Illumination - Pin 6
Brown - Ground - Pin 4
Blue - Perm live - Pin 5
