Touch Screen stopped working
roks
Hi All,
Not sure what happened but the touch function does not work. Camera and the buttons working.
Anyone see this before?
Well, took it apart yesterday, there appears to be a burn mark on one of the tracks on the digitizer. Guessing cleaning material made its way in the somehow.
I've ordered one of eBay from china, hope that is yet and nothing else. If that the doesn't work, could I replace the unit from another Auris?
There appears to be a lots of them from the Hybrid versions, will there those work in mine?
The screen boards are the same, I take it you have a Touch being 2013, I have replaced a few Touch2 screens what where cracked or scratched
I take it you have tried the reset and calibration in the hidden menu(s)
😕 Didnt realise there was one....
Found a complete unit (86140-02330) with satnav module (86840-0W013) attached, with the satnav module work?
It's the same as the touch2 hidden menu
yes the nav will work just make sure it comes with the patch leads you will also need the GPS antenna
Thanks mate, its got the main cable G is attached but there appears to be another small cable H in the picture thats missing.
Edit:
This is the unite I am thinking of buying might just use the whole thing if it works.:
Cant do the hidden menu as the touch function is not working....
Got the screen digitizer replaced, still not working. Either the new digitiszer is faulty or there is a wider issue with the unit.
Will a unit from a hybrid model work on a petrol?
Your best off fitting the same part number as the existing one, sounds like you may have cooked the driver on the display board
Thanks, for the same price, I found a Touch 2 & Go from a Petrol car, I went to pick it up so I tried it on but not all the wires connect.
I was left with this wire (see pic), nowhere to fit, any idea what this is for?
Also the radio was hissing even when I pressed radio off knob, is wiring loom is different for Touch 2?
Regards
The loom should be the same, did you have the aerial plugged in ?
16 pin is for the aux in/usb and comes from the multimedia interface the touch2 has this built in
I think I did...
So by not connecting that cable, I am not losing any functionality?
Only the factory usb and aux but if you had the same unit it wouldn't have had that anyway
be careful with USB leads off eBay the ones I have got were wired wrong
So the usb port next to the seat heater switch will not work? So where does the USB cable from back of the unit go? I thought that went to the usb plug on the dash? ...sorry Bob try be clear.
I guessing you are talking about the link cable between the satnav and radio? The cable is attached to the unit.
The Touch2 is the later radio 2014/15 onwards
In the early Auris the usb from the dash goes to a multimedia control box that then plugs back into the factory radio via the 16 pin connector you asked about
The Touch2 does NOT use the multimedia control module the Usb plugs directly into the touch2 via a grey 4 pin plug
So to use the usb you need to make a cable/add a new usb port
GPS should be the GT5 type, remove the USB port and see if it's the same type of plug as there are a few variations
Appreciate your help Bob,
It appears that the GPS and DAB connectors are different on the Touch 2. The inside connector is round where as on the Touch its square.
I think I can live without the DAB for now.
The earlier GPS is the GT5-1s, sorry my mistake, The touch2 uses an SMB connector with Toyota housing
As you have the nav module the usb plugs in to it and not the DA
On 12/1/2020 at 7:43 PM, flash22 said:
sorry my mistake
Not necessary mate, you've been very helpful.
Correct, but the DAB antenna goes in the DA, and its the mirror image of the GPS antenna (smb)
Correct, you can use an SMB female and hot glue it in place pics for reference, same goes for the DAB
https://www.toyota-4runner.org/5th-gen-t4rs/263024-entune-retrofit-basic-non-nav-non-jbl-entune-swap.html
You know what, I completed forgot that i added the information about the DAB/GPS to the Touch2 thread, also found the manufacture of the connectors
Ok, finally my touch 2 with Go arrived, its from May 2014, so I guess its touch2 gen1.
Everything seemed to work at first, including the USB until I put it in reverse. The reverse cam does not work!!!
I am guessing that 16pin connector has something to do with it. I have a feeling I need to connect the 16pin cable to the 24pin connector on the Touch2.
Is there any converters or is there a easy hacks?
Any pin outs for the 16 pin connector?
Thanks.
