Water Temp Sensor ------
- A - Go -
Hi, a quick question... where is the water temp sensor located on the car and is it an easy access to it?
Any pictures possibly of its location.
Thanks..
J
For a temp sensor to work correctly it needs to be in the flow of water if try to tee off the ecu sensor all you will do is cause both sensors to read high
you can put it in the top rad hose but it will only read correctly with the stat open
Ok, so where on the hose can i put the sensor? I have a 28mm sensor joint pipe but decided to use the sensor in the block rather than cutting into a pipe etc..
J
On a straight part, get your self a top hose first then if it all goes wrong you have a back up
Cheers!! 😀👍, will do !!
J
