USB port
jonbark
USB port does not fit usb stick very well and does not register has anybody else had this problem?
Is it a USB slot or just an Aux port missing its cover?
A picture may help
It is the slot itself works with iPhone but not usb sticks,i have trid several.Can not send a picture at moment.
...and just to be clear on what you mean by "does not register":
  1. Take a USB stick, connect to a computer, transfer a series of audio files (e.g. MP3) to the stick
  2. Connect the USB stick to the slot in the car, turn on stereo
  3. Set stereo input mode to USB (not FM/DAB/CD etc.)
  4. After a minute (the stereo needs to read the list of file names), the files can be played through the stereo
It should work like this https://blog.toyota.co.uk/toyota-touch-go-how-to-play-music-via-bluetooth-or-a-usb-device
what are you experiencing? What sort of files (e.g. .mp3, .wav) are you using?
The USB stick needs to be formatted in fat 32 on a PC (mac doesn't format in fat32 reliable) no bigger that 32gb as you are dealing with 10 year old hardware designs
What radio do you have, Touch2 ?
On 12/2/2020 at 12:19 PM, jonbark said:
USB port does not fit usb stick very well...
As the old joke says...
When the person who invented the USB drive dies...
They’ll lower his coffin into the grave, realize they put it in the wrong way and have to do it again.
Thank you Flash 22 when i got a fat 32 usb stick problem solved> Cheers
