Bike towbar for Aygo
Aygo Bex
Hi guys,
In need of a 'wheel on' bike carrier for a couple of Pashley bikes (walk through frames so normal bike carriers not viable, plus 47kg of weight). Thinking a towbar type is the way to go. Has anyone dared to fit such a thing to their aygo? If so, have you got details of make, model & where to obtain? Any help much appreciated. Many thanks in advance, Becky.
The Aygo isn't rated for towing, so towbars aren't available. Westfalia did produce a rear mounted bike carrier for the first generation Aygo (2006-2014), but not sure whether it is compatible with the second generation Aygo (2014 onwards). See https://shop.westfalia-automotive.com/accessory/350047600001
You could contact Westfalia to ask whether it is compatible, or one of their UK suppliers (eg. PF Jones).
Also Toyota do not recommend using a Roof Rack or bars for the second generation Aygo, and don't provide a weight limit for using one.
1 hour ago, 54Fifer said:
Can I point you at this thread.?
The towbar is for the first generation Aygo, and may not fit the second generation.
