P2102 fault coming up on my 2005 1.8 petrol Avensis.
G Atwal
Hi guys, have had a nightmare getting home in limp mode after car simply lost power on the motorway. Luckily I was just approaching a junction and managed to leave and take an A road home at 20 mph.
Have now had an obdll on it and its giving me P2102 'throttle actuator control motor circuit low'.
Any ideas, please help?
start with cleaning the throttle body, also check the air box and filter make sure is hasn't sucked up anything, and check for squatters
Flash22 you're a star, thank you. Will do first thing tomorrow afternoon lol. Happy New year mate...🤙🏾
Worked like an absolute charm. Thanks again mate. Idling at 680 and purring like a kitten...much appreciated.
Got too happy too soon. The P2102 is back and won't clear even with the obd11.
Any ideas what else I can do?
 Throttle cleaner spray.
  • 1 year later...
Hey mate. Have you solved the problem and what was it? Got 2013 auris with the same problem. Thanks
Likely to be cut cable or bad connectors in the plug. Unplug , clean with contact sorry , inspect for damage or missing pins, measure the voltage and c,Dan the throttle body , these are the first steps you need to do.
Good luck 👍
