jcr71 2 Posted January 2 Share Posted January 2 hello all i found this forum when googling this morning. my issue is with the radio in my partners car. i think its probably the quietest radio ive ever heard in a vehicle, and ive been around for a few years. its adequate for listening to the radio, but even at full volume i dont have to raise my voice hardly at all to be heard. the car has satnav and a reversing camera. and the software version on the radio is 6.7.0 wl. so my questions are- is the shockingly low volume correct? if yes, and it is not fixable, can i buy a better quality sound system that would just be a simple swap out without any rewiring and would keep the satnav/camera features? thank you jason Quote Link to post Share on other sites
jcr71 2 Posted January 2 Author Share Posted January 2 ps the car is on a 66 plate. Quote Link to post Share on other sites
1.8 hybrid 17 Posted January 2 Share Posted January 2 is the fader set to the rear Quote Link to post Share on other sites
flash22 669 Posted January 2 Share Posted January 2 First off check the balance and fader settings 60/40 or 70/30 to the front is ideal as you want the sound stage up front You can also do a speaker test in the hidden menu - diagnostics check - SPTest Hidden menu Press and hold the Car button (Holding the Setup button instead takes you into the full diagnostics check) Turn the headlights on and off 3 times or Press the Vol/Power button, so it displays Audio Off Press the MENU button Touch «Display» Touch «Screen off» Quickly press ">" 5 times and immediately press "<", 5 times turn the ignition off to exit the menu iirc 6.9.0 WL is the latest free update for the nav log in or setup an account on My Toyota - top right, click on My Toyota - My Vehicle then add a car and/or click Register my multimedia Quote Link to post Share on other sites
flash22 669 Posted January 2 Share Posted January 2 Just a thought do you have the JBL upgrade ? Quote Link to post Share on other sites
jcr71 2 Posted January 3 Author Share Posted January 3 thank you for the replies folks. im not with my partner at present, thanks to work. i will try your advice once i have access to the car again. i have no idea if the car has a jbl upgrade, it was brought second hand. other than the stereo, my partner has been very pleased with the car. Quote Link to post Share on other sites
1.8 hybrid 17 Posted January 3 Share Posted January 3 my partner has a 66 plate with the touch 2 audio unfortunately i hear when she comes home with a low dum dum dum dum noise 1 Quote Link to post Share on other sites
jcr71 2 Posted January 6 Author Share Posted January 6 just a quick update- had a look at the radio today and managed to find the fader after a bit of head scratching. for some reason it was set to +5 rear. i changed it to +4 front and it made a massive difference to the volume. hopefully it will be loud enough for my partners podcasts now. thank you once again for the help. 1 1 Quote Link to post Share on other sites
flash22 669 Posted January 9 Share Posted January 9 Thanks for the update Quote Link to post Share on other sites
