2017 Toyota Corolla Engine vibrates around 2800-3000 rpm
PPSS
I recently bought used 2017 corolla, 32000 KMs.
When the RPMs reach 2800-3000, car's engine runs hard and vibrates, vibration can be felt in steering wheel.
When the RPMs are above and below the 2800-3000 range, engine runs smooth.
It doesn't matter what speed it is.
Any help?
Thanks.
Hi, what engine and transmission is the car ?
Vibrations can be as a result of many things, bad engine mounts, injectors, poor quality fuel, drive shafts, egr, bearings on the gearbox and or differential and more. A bit more info can help determine. Have you visited a garage yet and what they have found?
  • 1 year later...
Hello sir I have exact same problem with my car could you please tell me how you solved. Toyota Corolla 2017
Which engine? Petrol, diesel or hybrid?
  • 8 months later...
I just solved mine after much time and money spent. It was the rear exhaust donut gasket that was loose and slightly sideways. I watched a mechanic replace both the front and rear donut gaskets together with new bolts and springs and fixed this annoyance once and for all. No more vibration, and no more humming.
