t25 rear caliper carrier bolts - size or part No.
CalumMac
Does anyone know the size of the rear brake caliper carrier bolts (hub to carrier) for an Avensis T25? or even a part number for replacements, as mine have rounded and I can't seem to find much info on them.
Many thanks,
Calum.
It should be 90105-10404 and it will be a graded bolt (tensile strength)
you need to check that with a main stealer
https://www.ebay.co.uk/itm/Genuine-Toyota-Auris-Avensis-Corolla-Rear-Caliper-Pad-Carrier-Bolt-2007-2012/223584358958?hash=item340eaa922e:g:260AAOSwxSNfhGcW
you get screwed on the postage - prob £1.50 each from the dealer
Thanks guys, much appreciated. I'll give the main stealer a ring and see what they can offer me.
Thanks again,
Calum.
