Horn comes on when reverse gear selected
philip F
Hi anyone any idea why the horn would sound when reverse gear is selected. I am guessing its a damp problem with all the rain but not sure where the crossover would be.
Seems to be a common issue i would check the ground near the relay box and the relay/relay box its self
A thread from just a few days ago........................
As it is probably a damp issue would you recommend a light spray of WD40 over the fuse box and relay to see it it clears the problem
