How to Top up gearbox oil
John M cNeil
Have a Proace 2016 need to top up gearbox oil after changing driveshaft.
Anyone have any ideas where the top up filler hole/ plug is?
Hi, it depends of the model of the transmission, auto, manual or hybrid., the last two usually when car is levelled and you undo the inspection plug the oil should start dripping if not you need to top up up until starts dripping, that’s how gear oil is checked and oil is added, u can use a pump or tube and funnel from above.
Regards
Moved to the Proace club
  • 1 year later...
I have same problem with Proace 2.0 122hp year 2018.
I should top  up gearbox oil after driveshaft temporary removal
and wondering if anyone could help me for finding filler plug.
Also would be good to hear what oil I should use / has been originally used.
Toyota Proace 2.0d
Year 2018
Manual (6)
90kW/122hp
4WZ-FTV
