Fast charging usb ports
Cbatoday
Wonder why Toyota only saw it fit to use standard power charging from the usb ports.
Surely fast charging would have been the way to go.
Even better would be more data ports. I don't understand why the port in the arm rest is charging only. My Jazz had two ports in the armrest, both carried data. It had another in the same approximate position as the Corolla. It also had an HDMI port next to the front USB so that you could play video on the infotainment unit.
