Dala 0 Posted January 24 Share Posted January 24 Does anyone know the part number of the shelf to order from a dealer? Quote Link to post Share on other sites
TonyHSD 778 Posted January 24 Share Posted January 24 Hi and welcome. Local Toyota dealer, if not available in your country and you are sure these exist in other markets and can fit your car without additional modifications you can purchase from abroad, again main dealers only as this is a brand new model. Regards Quote Link to post Share on other sites
Dala 0 Posted January 24 Author Share Posted January 24 Hi, I'm not sure if it can be used for model 2017 - 58410-0D050-B2 Quote Link to post Share on other sites
TonyHSD 778 Posted January 24 Share Posted January 24 32 minutes ago, Dala said: Hi, I'm not sure if it can be used for model 2017 - 58410-0D050-B2 Probably not, these two are very different models. No similarity between except the name. Quote Link to post Share on other sites
Bernard Foy 100 Posted January 24 Share Posted January 24 16 minutes ago, Dala said: Hi, I'm not sure if it can be used for model 2017 - 58410-0D050-B2 I have cut a perfectly fitting template from hard cardboard. When lockdown is over I will buy a half sheet of 3/8” plywood and jigsaw a shelf from it. I will then cut across the center of it and fasten both together with a piano hinge, and create a finger hole on the edge nearest back bumper. That will enable me to lift up half of the shelf to access easily the storage. I also intend to stick a 1/2” rubber strip where it rests on the supports, to eliminate rattle or vibration. I may then to complete the job either paint as near as possible to the upholstery colour or stick a covering of black rubber on the top. That’s my next project when lockdown eases a bit.🙏 1 Quote Link to post Share on other sites
Dala 0 Posted January 25 Author Share Posted January 25 could it be it? https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-2012-2020-Boot-Deck-Board-Part-Number-58410-0D050-B0-/360617438089#vi-ilComp https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-Hybrid-Rear-Boot-Parcel-Shelf-Black-2013-584100D050B2-/221837768166 Quote Link to post Share on other sites
Mick F 175 Posted January 25 Share Posted January 25 I made my own from MDF. Cut out two cardboard formers for the left and right, and then some more cardboard for the curved rear and accurately measured the straight distance at the front. Marked it all off onto the MDF, and cut it out. Couple of hours work. Mick. Quote Link to post Share on other sites
Dala 0 Posted January 25 Author Share Posted January 25 do you have any photos ? Quote Link to post Share on other sites
Mick F 175 Posted January 25 Share Posted January 25 4 hours ago, Dala said: do you have any photos ? Just taken three for you. One with the MDF floor lowered, one with it in the raised position, and one from the underside. (The L is for left as when the pieces were made separately, I had to make sure I assembled it correctly.) I made it from three pieces of old MDF I had kicking about. Joined the three together with pieces of wood glued and screwed together, and a length of angle aluminium to strengthen the front. The rear has a central support, but the front doesn't, so I figured it would be better to be stronger. Hole in it, so I can get a finger in to lift and lower it. The eagle-eyed will see a square piece at either end of the front. Embarrassed to say, I measured wrongly and made some cutouts that were't needed, so I glued two squares back in! Mick. 1 Quote Link to post Share on other sites
flash22 656 Posted January 25 Share Posted January 25 4 hours ago, Dala said: could it be it? https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-2012-2020-Boot-Deck-Board-Part-Number-58410-0D050-B0-/360617438089#vi-ilComp https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-Hybrid-Rear-Boot-Parcel-Shelf-Black-2013-584100D050B2-/221837768166 Both are for the gen 3 only difference is the colour your best off sending a PM to @Parts-King Quote Link to post Share on other sites
FROSTYBALLS 3,427 Posted January 25 Share Posted January 25 4 hours ago, Dala said: could it be it? https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-2012-2020-Boot-Deck-Board-Part-Number-58410-0D050-B0-/360617438089#vi-ilComp https://www.ebay.co.uk/itm/Genuine-Toyota-Yaris-Hybrid-Rear-Boot-Parcel-Shelf-Black-2013-584100D050B2-/221837768166 Both are for the previous generation Yaris - not yours - and one is a parcel shelf not the variable boot floor/deck board. Don't think Parts-King will supply the part number in order for someone to go and buy elsewhere. Quote Link to post Share on other sites
Bernard Foy 100 Posted January 25 Share Posted January 25 10 hours ago, Dala said: do you have any photos ? As yours Yaris is the new model, my pics might not be of any help as it’s a 2019 the previous model. However if you are useful with your hands, then I recommend getting a large stiff cardboard box and making a perfect fit template. Use it to cut out your own raised floor out of your most suitable material which must have good strength, proceeding as in my previous post. If you still want a picture of my template, let me know and I will post. You will be quids better off. Good Luck 🍀 Quote Link to post Share on other sites
Dala 0 Posted January 25 Author Share Posted January 25 thank you all Quote Link to post Share on other sites
Bernard Foy 100 Posted January 25 Share Posted January 25 7 hours ago, Mick F said: Just taken three for you. One with the MDF floor lowered, one with it in the raised position, and one from the underside. (The L is for left as when the pieces were made separately, I had to make sure I assembled it correctly.) I made it from three pieces of old MDF I had kicking about. Joined the three together with pieces of wood glued and screwed together, and a length of angle aluminium to strengthen the front. The rear has a central support, but the front doesn't, so I figured it would be better to be stronger. Hole in it, so I can get a finger in to lift and lower it. The eagle-eyed will see a square piece at either end of the front. Embarrassed to say, I measured wrongly and made some cutouts that were't needed, so I glued two squares back in! Mick. Hi Mick, my reason for choosing 3/8” inch plywood is for its strength which shouldn’t need support underneath 🙏 1 Quote Link to post Share on other sites
Devon Aygo 963 Posted January 25 Share Posted January 25 The high level floor in the new Yaris is not the same as the last generation, part numbers & installation guide HERE Quote Link to post Share on other sites
Mick F 175 Posted January 26 Share Posted January 26 12 hours ago, Bernard Foy said: Hi Mick, my reason for choosing 3/8” inch plywood is for its strength which shouldn’t need support underneath 🙏 As I said, I had the MDF kicking about. The whole job cost me nothing other than time. I even had the alu angle in the shed. If I'd wanted to spend dosh, I'd have used decent plywood. As it is, the floor is rarely used, so a cheap job does it fine for us. Mick. Quote Link to post Share on other sites
Bernard Foy 100 Posted January 26 Share Posted January 26 9 hours ago, Mick F said: As I said, I had the MDF kicking about. The whole job cost me nothing other than time. I even had the alu angle in the shed. If I'd wanted to spend dosh, I'd have used decent plywood. As it is, the floor is rarely used, so a cheap job does it fine for us. Mick. I must have another look at your job Mick, I never noticed the aluminum angle.😮 Quote Link to post Share on other sites
Bernard Foy 100 Posted January 26 Share Posted January 26 15 minutes ago, Bernard Foy said: I must have another look at your job Mick, I never noticed the aluminum angle.😮 I have looked again and it’s a great idea if I need to strengthen along that edge Mick, thanks for that 👏👏 1 Quote Link to post Share on other sites
Mick F 175 Posted January 26 Share Posted January 26 22 minutes ago, Bernard Foy said: I have looked again and it’s a great idea if I need to strengthen along that edge Mick, thanks for that 👏👏 There's even a bar code if you'd like! 😀 Mick. Quote Link to post Share on other sites
Bernard Foy 100 Posted January 26 Share Posted January 26 2 minutes ago, Mick F said: There's even a bar code if you'd like! 😀 Mick. And wouldn’t add any weight which is the object of keeping it lightweight and easy to install and remove 👍. By the way, any vibration or rattle noises when driving around with nothing sitting on it??🤔 Quote Link to post Share on other sites
Mick F 175 Posted January 27 Share Posted January 27 14 hours ago, Bernard Foy said: By the way, any vibration or rattle noises when driving around with nothing sitting on it??🤔 No, nothing at all, though ours is quite heavy being MDF .................. without measuring, I think it's about half-inch thick. Mick. Quote Link to post Share on other sites
