Help required
Bellariven
I require help locating the gearbox oil dip stick to check the level.
I'm having real trouble trying to get into first when stationary and doing some research thought I'd check that first :)
Would be helpful to know which engine and petrol or diesel.
As far as I know there is no dip stick as gearbox is sealed,as far as getting first year sounds like clutch is worn.
