1zz fe engine from Toyota wish ecu pinout required, help needed ecu # 4741
Danish Raza
Hi every body. I am swapping 1zz vvti 1.8 engine in my 1998 London model Toyota Carina, i need the pin out for this ecu
This ECU is 4741, with 5 connectors. Also i need Carina E ABS unit pinout, the Bosch RHD one.
