Mariosskoutaris 1 Posted January 27 Share Posted January 27 I have the Auris d-cat and my mechanic says I should inflate my tyres(225/45/r17) at 2.2bar/32psi but my front wheels seem to be a little deflated , probably its because of the heavy engine in front. Anyone with the same model that can tell me what they put on their tyres? Thanks in advance. Quote Link to post Share on other sites
FROSTYBALLS 3,424 Posted January 27 Share Posted January 27 Isn't there a sticker/plate on one of the B pillars showing the correct tyre pressures? Quote Link to post Share on other sites
TonyHSD 773 Posted January 27 Share Posted January 27 Front one needs to be more, you can check on door shut labels. According to this site should be 2.5 bar front and 2.2bar rear. https://www.wheel-size.com/size/toyota/auris/2009/#trim-22-d-eudm-174 Quote Link to post Share on other sites
Mariosskoutaris 1 Posted January 27 Author Share Posted January 27 Just now, TonyHSD said: Front one needs to be more, you can check on door shut labels. According to this site should be 2.5 bar front and 2.2bar rear. https://www.wheel-size.com/size/toyota/auris/2009/#trim-22-d-eudm-174 Just now, FROSTYBALLS said: Isn't there a sticker/plate on one of the B pillars showing the correct tyre pressures? My bad i thought i checked for the label and it wasn't there but its indeed there. Thanks a lot for the help tho 1 Quote Link to post Share on other sites
