Toyota Auris 2.2L d-cat recommended tyre pressure
Mariosskoutaris
I have the Auris d-cat and my mechanic says I should inflate my tyres(225/45/r17) at 2.2bar/32psi but my front wheels seem to be a little deflated , probably its because of the heavy engine in front. Anyone with the same model that can tell me what they put on their tyres?
Thanks in advance.
Isn't there a sticker/plate on one of the B pillars showing the correct tyre pressures?
Just now, TonyHSD said:
Front one needs to be more, you can check on door shut labels. According to this site should be 2.5 bar front and 2.2bar rear.
https://www.wheel-size.com/size/toyota/auris/2009/#trim-22-d-eudm-174
My bad i thought i checked for the label and it wasn't there but its indeed there. Thanks a lot for the help tho
