Hilux alloy Wheels 2014, Will they fit, Toyota Land Cruiser J120 2008
Pano
Hi, Kindly ask for advice on the following issue. Can any any one verify, if : Toyota Hilux 2014 Alloy wheels will fit Toyota land Cruiser J120 2008 model
Thank you
Pano
  • 4 months later...
Hmm, I'm not so sure about the sizes. However, just in case those don't work out for you, I may recommend these tire and wheel packages I saw online. Not only are they high-quality, but they're very affordable as well.
The stud pattern is identical, check the offset.
