2015 Aygo water leak
Andy Link
I have a leak that results in a puddle in the passenger footwell. I’ve fitted a new seal on the passenger door, but the problem remains, I can’t see any other source of the leak and wondered if anyone had any pointers on where to look next.
thanks in advance
There are umpteen number of threads on this topic Inthe internet (even you tube videos). Have you checked them out?
dont blindly replace parts...a few trims need stripping off in the suspect area then watch from inside as a help sprays the car with a hose
front footwell...id look at the door membrane
Assuming you have a later Mk2 Aygo then water leaks are rare and none of the issues affecting the Mk1 model are repeated, obvious point to check:
  • Does you car have AC? if so then there is a drain pipe exiting the bottom of the heater/ac unit which passes out through the bulkhead, make sure this is fitted and with the AC running you can see water dripping from the rear of the engine bay.
  • Is the original windscreen fitted/have you had a new screen ?
  • Any bodywork completed
Assuming you have had the car a while? has anything been worked on recently ?
