2001 1CD-FTV techstream live data...
fftoyota
Hello,
Someone who knows how to read these data correctly to see if they are within the parameters.
Made after replacement the injector seals ...
They look fine to me, if they were out of spec you will have a pending/active code(s)
Ok,
Trouble codes are clean.
Unfortunately the obd2 cable took a long time to arrive and I was only able to test it after the repair.
  • 9 months later...
Hello again,
Does anyone know why i dont see the parameter to enter the compensation codes?
Thanks...
I think I've already read here in a RAV4 thread that it wasn't necessary to introduce injector codes on older models. that's why the parameter doesn't appear on my Corolla? it's from 2001...
Answer myself!
After contacting a Toyota dealer i was informed that it is not necessary to program compensation codes.
  • 3 months later...
On 12/17/2021 at 9:35 AM, fftoyota said:
Answer myself!
Hi, I am having same issue with the code compensation for injectors not showing in techstream. Mines a 2005 RAV4 mk2. Can I assume that the remanufactured injectors I have purchased for it also does NOT need reprogrammed?
I think so, until 2006 i don´t think they need.
Is like this?
Fuel injector
Fuel injector
Fuel injector
