Toyota Alphard hybrid 2004
Lesso9
Hi Toyota Family, I own a Toyota Alphard 2004 hybrid. The car has 140k mileage, my issues are;
1. Hybrid Battery doesnt charge to full one bar left,
2. Another issue is sometimes the hybrid system error light turns on but not frequently
3. Its a e-four but when the system engage it gives the kick sound, is it normal?
Hopeful il get help on fixing the issues.
Moved to the Alphard forum.
1. That's normal
2. You need to read the codes, if i had to guess i would say it's the Brake Control Power Supply Assembly, but it could also be a dying Battery
3. check the rear motor is engaging and make sure the both rear drive shafts are good
  • 2 months later...
Hi,i have same problem ,any tips with a solution?
  • 5 months later...
Hi did you find the problem? I have the same Problem.  Please let me know.  Thanks.
1. Hybrid battery doesnt charge to full one bar left,
