Stereo change
Richard4
Can I replace the stereo in my 2014 Toyota Yaris  with CD player for one out of a 2019 Yaris without CD
any help would be much appreciated thank you
What radio do you currently have ? Is it a touch screen ?
OK its a pre facelift mk3 with a Toyota touch yes it will fit and its plug and play, if the new one has DAB you will need to add a DAB aerial
iirc the surround is a bit bigger, so you will need to trim the dash pad down, trim the surround or fit a 2015-18 dash pad*, the later 17 onwards touch 2 (silver buttons) the surround unclips from the radio
Pic's for reference
17-
https://www.ebay.co.uk/itm/TOYOTA-YARIS-MK3-2014-RADIO-STEREO-HEAD-UNIT-SURROUND-FACIA-PANEL-86451-0D060/274697252735?epid=4027239924&hash=item3ff53b6f7f%3Ag%3ApZAAAOSweu1crc0F&LH_ItemCondition=4
14-17
https://www.ebay.co.uk/itm/2014-TOYOTA-YARIS-RADIO-SAT-NAV-SURROUND-TRIM-HAZARD-SWITCH-86451-0D030/124386977460?epid=6023904283&hash=item1cf60aa6b4%3Ag%3A2lIAAOSwfgpfiCxY&LH_ItemCondition=4
11-14
https://www.ebay.co.uk/itm/Toyota-Yaris-2011-2014-MK3-SAT-NAV-RADIO-SURROUND-TRIM-864510D010/284207511810?hash=item422c167902%3Ag%3AwUAAAOSw7Q1f-6DB&LH_ItemCondition=4
mk3 stereo removal - Copy.pdf
I have recently  added DAB to my 2015  Yaris ICON I used this aerial    Imwell DAB Aerial Car Radio Signal Amplifier GSM Patch: AmazonSmile: Electronics     which I have stuck to the top of the windscreen to left of the mirror ( looking from the inside ) but had to use a adapter from this pack in the pack of the radio    Bingfu DAB Car Aerial Adapter SMB Female to Male: AmazonSmile: Electronics      A fairly easy job , took less than a hour and that included swopping the Sat Nav module of the old radio on to the new one with DAB
Thanks for your replies. I was looking at the one with the silver buttons
