1991 Hiace - engine dies on starting
Will_90
Hi all
1991 manual 2.4l petrol Hiace - when I start it from cold in the morning it'll start, but over 5-10 seconds of idling the engine will gradually 'die' and then turn off as if it's not getting enough fuel. Second go it starts fine, later in the same day it'll start fine, and if I touch the gas during the 5-10 second period after the first start it'll be fine, so it seems like the engine isn't getting enough fuel on starting when it's cold.
Any similar experiences/suggestions?
Thanks in advance!
