Toyota avensis acceleration problems
philb699
my 05 Avensis d4d tspirit runs fine when cold but as soon as it gets warm will not accelerate below about 3000 rpm once it gets above this it runs as normal, whilst its struggling to accelerate it does produce some smoke but not large amounts  and once it picks up does not smoke any idea's? have changed fuel filter and air filter no engine lights on
Classic case of a dirty or faulty EGR valve. First step is to clean it, solves 99% of the issues.
as above, could be not totally shut due to carbon build up thus boost pressure escaping until revs/pressure overcome the boost leak rate..
any other boost leak is also possible wether it from a pipe or intercooler
warm air is less dense than cold air maybey explaining how its better when cold...
also could also be scv performing better when cold / cold fuel
or -duff injector leaking when warmed up
or turbo bad
is it black smoke / overfuelling ?
to all those who offered advice i thank you it was the EGR valve many thanks
  • 2 years later...
my 05 Avensis d4d tspirit runs fine when cold but as soon as it gets warm it’s rpm starts to flunctuate and as soon as it gets to a U turn will not accelerate once it’s ac is turned off, it runs as normal, and once it picks up, I turn on the ac back. any idea's? have changed fuel pump and cleaned fuel injector.
