Aygo Go Tom Tom sat nav screen not responding
98avensis
Hi everyone, we have just bought a 2011 Aygo Go with the Tom Tom sat nav, it powers up fine and the map shows but touching the screen doesn't open any menus etc, it seems to be frozen, it hasn't got an sd card fitted so I don't know if that would make a difference, I've pressed the reset button for 20 seconds then powered it up but that didn't help at all 😞 , has anyone else had a similar problem?
Thanks ever so much.
Release the tom-tom by the catch on the right, make sure the pin and contacts are clean
Did you do the reset by the pinhole in the bottom of the unit ??
Hi Flash22
Thanks for your help
I've just cleaned the pins and contacts and it's sadly still the same.
I did press the reset button in the bottom for 20 seconds with the unit switched off when I reset it the other day.
Neither of the buttons to the left of the unit (when in the car) seem to do anything either, the maps showing and has good gps signal/location.
We haven't got the SD card, does it need to be fitted to function do you know?
Thanks again
Paul
If it was a trade purchase go back to the dealer.
As a TomTom device it is supported by TomTom and may need updates or recovery you will need to install TomTom Home HERE and see if the unit responds
Ah, standalone TT. I have had that with a Garmin and a reset was required.  For SatNav help try PocketGPSWorld.com.  I had a quick browse and didn't find anything, but you could pose your own question.
Thanks for your replies Roy124 and Devon Aygo, Roy I was made aware of the issue by the dealer and the price I paid took it into consideration. I'll take a look at PocketGPSWorld, I have done a reset already, thanks.
Devon Aygo I'll install Tom Tom home this evening and see if that helps.
Does anyone know if you need to have an sd card fitted? I wouldn't have thought so as the map shows fine, but just in case!
Thanks again for your help
Paul
Paul, a couple of other points that might be relevant.  Does it know where it is?  If it has not been active for sometime its view of the satellites might be very different from the time it was last used.  The second, and also left field, is it might be in dead space.
I cannot explain the latter easily but it happened sometimes with my Garmin and always in the same area.  We would drive down to the cruise terminal at Southampton and in the vicinity of the docks it would simply freeze.  Happened about three times.  Never in precisely the same place but twice I had to do a reset and it only cleared once we were away from that area.
Of course it could be fried.
Hi everyone
Thanks for all your help, all fixed now 🙂
I tried to update via a pc but as soon as I plugged in the usb cable the Tom Tom asked if I want to connect to the computer so was stumped!
So I took the Tom Tom apart hoping to find a ribbon cable may have come loose, but there's only one to the screen and that was displaying ok (I did unplug it and plug it back in), I checked the screen was clean where it fits inside the bezel and tried it loose, outside the bezel but it was no different.
I took the part number of the screen and found a uk eBay seller selling 'new' screens for £25, ordered one and fitted it and it's now working perfectly, really pleased.
Thanks again for all your help everyone.
Take care
Paul
  • 1 year later...
On 4/19/2021 at 8:00 AM, 98avensis said:
Hi everyone
Take care
Paul
Hi Paul. Can you send me the link for the UK screen seller please
