Corolla 2005 exhaust heat shield
LeoSteven
Hello 🙂 I'm looking for the part number for the exhaust heat shield on a 2005 Corolla. It's the one that goes under the fuel tank. Any help would be appreciated. Thanks!
Have the same problem, its been mentioned in the forum before as it costs about £140 from Toyota but they said there was another supplier you could import from for about half the cost but looking on that site they no longer do it.
Had been thinking of using some of the diy heat /exhaust pipe covers and shield material you can get from the diy market but not sure how they would be accepted by the MOT inspectors ??
The T25 Avensis uses the same part 😉
you can find them used, also check with the main stealer as parts from japan have a hefty shipping charge built into the price
