DAB radio how to make a list
Thomas76
Hi everyone. I’m sorry to seem a bit daft but how do you make a list on dab radio? I’ve tried everything but it says that list is empty and doesn’t show any numbers to add it to( like 1-6?? I think it’s the go 2 system ( no cd slot).
Also is there any way of adding sat nav to the same system ( download or something .
Quick update but this didn’t work sorry any ideas. I don’t want to pay for something that could easily be sorted. Would it be covered under warranty or something it’s a 64 plate.
The sat nav is an add on module
if its not picking anything up  you may have an aerial problem make sure its tight and the plastic of the whip is not cracked
you can go into the hidden service menu and see if you have any fault codes
Press and hold the music or car button and turn the sidelights on and off 3 times - Failure Diagnosis - press DA
6 minutes ago, flash22 said:
Do a INIT reset from the hidden menu using the car button, does the car pick up fm stations ok ?
Picks up fm stations no problem.
I have no problem with dab I just can’t get or make a list on dab radio?. Sorry about all this ( Toyota’s new radio system is a bit hard for me to understand sorry).
As i said in my first post
press manual, then go into settings (gear icon) - refresh list (you may have to press and hold the button, the screen will change  to one with "Station list is being refreshed..." and a cancel button - let it update (this may take up to 2 mins)
Done all that mate but still no luck. Thank you so much for all your help.
You need to do a INIT reset - hold the car button and headlights on/off 3 times
What software Version do you have ?  Setup - General - System information
Not sure which ‘ensemble’(?) you are tuned into on your first photo…is it “HereWorc” ?
In which case there may only be one station ‘available’, hence no list.
Have you tried changing to the National DAB ensemble and ‘tuning’ ?
This is the relevant page in the manual…..
The way dab works is there are multiple stations on a frequency know as a multiplex so it shouldn't pick up just one station
there is the chance where you are, you are in an RF black hole but as your getting FM stations that doesn't seem to be the issue
