Engine Noise During Acceleration
CLIVE4004
I changed my 6 year old one owner Aygo last November for a new Aygo X-Clusiv. I'm a big fan of the model and very pleased with the new car in almost every respect apart from one. When the engine has warmed up, and not before, I get a sort of rasping sound under load. I don't think it's from the engine and feel it's more power train associated. As my previous Aygo was 2014 I hope that some modification has taken place to alter the engine noise and that my concerns are unfounded.
 I haven't contacted Toyota yet as it's only a mechanical noise and may be normal with newer models. Can anyone advise me please?
I had an aygo as a courtesy car while my auris was in for service a couple of years ago.
was shocked at how noisy the engine was under acceleration( as motoring journalists ) have said was ok once up to cruising speed on the motorway, maybe normal.
The Aygo is a 3 cylinder engine which makes a really nice throaty sound, yes, different to a 4 cylinder engine you may be used to. It’s a characteristic of the engine.
do you think it could be that noise.
Thank you for your responses guys. I wouldn't be concerned had my previous Aygo, an early 2nd generation one, made the same noise but I had it for 6 years and was never aware of the noise that this one makes. Perhaps the noise baffling was more efficient on my last one. Because of lockdown restrictions I have only done 1700 miles in this one and I have faith in Toyota for reliability and precision. I'll plod on and get used to it. I think the theory of a 3 cylinder engine is a great idea with bigger pistons, tougher conrods and bearings etc.
In October last year I swapped my 2008 model for a new 2020 model, I too noticed the very different engine noise.
Then I looked under the bonnet and saw a completely different inlet manifold and on doing some research found that the new models have a different variant of the 1KR-FE engine that has many differences:
- longer inlet tract that enhances torque
- 2 injectors per cylinder
- variable valve timing on both inlet and exhaust valves
- heated EGR system
https://toyota-club.net/files/faq/19-10-20_faq_kr-engine_eng.htm - look at the type '18 details.
When you take all of those into account it's really not surprising that the engine sounds completely different. I actually prefer the gruffer engine note under acceleration as IMHO it gives it more 'character'.
- heated EGR system
Dave
Thank you for this most comprehensive response. Clearly it has given me all the assurances I need. The amount of data via the link is incredible. At the risk of sounding crass, engineering has come a long way since my first BMC "A" Series.
Clive
