Will a diesel gearbox fit a petrol engine?
ToyotaGang
I have been wondering for a long time. If you can pair a petrol engine with a diesel transmission. Is it possible?
Why would you want to ?
No, You can't pair diesel gearbox to petrol engine.
Petrol gearbox: 333770E.png
Diesel gearbox: 333761.png
Bolts position doesn't match. Clutch housing (to engine block) have also bolts lot different places between diesel and petrol.
And then there is problem with gear ratio etc..
Thanks. I just wanted to know.
Even though the OP has got the answers, I notice he has a T27 from his profile. Since all manual T27's regardless of fuel type have 6 speed, I would only assume it is difficult to source a replacement petrol version, since there are more diesel gearboxes available! Unless the housing is destroyed, it would better to find a gearbox specialist to replace any damaged/worn internals. Otherwise wait until a suitable matching second hand gearbox becomes available.
Edited by Konrad C
spelling correction
