Micro SD slot
50p
another newby question, I cannot find it mentioned in the online instruction mannual so far. MY2021 Corolla Excel HB
What is the what looks like a micro SD slot on the left of the centre console, next to the 'gear' selector for? Is it for updating the maps on the satnav? Could it be used to play music files?
I think this is what you're looking at - The pic is from a LHD car so the usb port will be on the left in your car.
I use this port to connect my phone for Apple Carplay.
It's in the manual under "shift lock system"
Hi jack Spratt .. thanks for the reply.
It is not the USB port I was referring to but what looks like a micro SD card slot. It's located in the LHS of the piano black surround of the 'gear' selector. I will take a picture of it tomorrow
Thanks camellia30, I will check tomorrow when it's a bit lighter out.
The slot I'm referring to is on the left hand side and has no cover to remove? Maybe missing of course.
The slot is in the cover, that's how you prise it off to reveal the button
Ahh, thanks for that, much appreciated
This is not a micro SD slot. It is for unlocking the gear selector in case of problem.
