Install a Toyota 6CD Changer?
TYdriver
I recently bought a 2002 Toyota Yaris GLS which has the tape deck in the central console. Below this are the controls for the radio (as standard) and below them is an aftermarket radio - where when new it would have had an empty space.
I haven’t taken apart the dash to see what cables connect the aftermarket radio to the original, so I don’t exactly know what’s behind there (yet). My question really is, if I was to remove the aftermarket radio could I install a Toyota original 6CD changer in its place, and would it connect to the original radio (and function correctly)?
Many thanks,
Alex
Why bother ? If you can find a changer its going to be 18-20 years old, reliabilty is going to be a big problem, does the aftermarket radio have usb, or does even play mp3 cd's
the changer should be the old 12 pin plug
https://pinoutguide.com/Car-Stereo-Toyota-Lexus/Toyota_1990-2002_CD_Chang_pinout.shtml
6 disc change for the Yaris - TM0561
Under seat changer
https://www.toyota-tech.eu/aimuploads/{8425CD6F-CE15-4841-9EFF-69947843D3A1}/AGP1R-J-0-F.pdf
